跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
What could be wrong if "internet recovery" won't go through?
Got this laptop from auction, and was told it was linking with another Apple ID for Activation.
When I turn it on, no matter if press “Command” + “R”, “D" or “Option” key, it always go to “Internet Recovery Mode” with the “Global” rotating, but most of the time it won’t finish loading, instead it returns error like "support.apple.com/imac/startup - 2100F”.
Is this due to Activation locked?
Any thoughts?
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Power it down, then connect it to an Ethernet source using an Ethernet to USB-C adaptor, then power it up while holding Shift + Option + Command + R until you see a progress bar or a rotating globe. It should then boot into a version of Internet Recovery Mode. From there you might be able to tell whether or not it's Activation Locked to an Apple ID. If that procedure doesn't work you may need to do a full device restore by putting the device into DFU mode and connecting it to another computer running Apple Configurator. Good luck!
这个答案有帮助吗?
得分 0
6条评论:
@Zach — got it through loading with Ethernet connection setup, and did found it was linking to another Apple ID at activation stage. Can booting it into DFU mode with connecting to another computer running Apple Configurator unlock it? Any thoughts?
完成的
@lovecd As far as I know, there isn't any way to remove the Activation Lock with Apple Configurator. You may be able to get the device to be usable though by erasing the device in Recovery Mode (if you can't get to Disk Utility in Recovery Mode, click one of the options in the menu bar in top left corner of the screen and you might see an "Erase this Mac" option). If you're able to erase the device and reinstall macOS, then during the set up process you might be able to skip the Activation Lock screen by making sure it's disconnected from Ethernet and Wi-Fi during the set-up process after the install. The device will still be associated with that Apple ID going forward but at least it would be usable. Good luck!
完成的
@zpl -- I was able to get through the internet recovery process by connecting the laptop with ethernet connection (not wifi), and able to find that "erase this Mac" option from the top menu bar, however, it simply come back to "internet recovery with the global rotating" again after confirming the erase, I guess Apple just won't make you bypass the activation stage no matter what. Any thoughts?
Thanks,
完成的
If you do that process with the Ethernet cable connected the entire time it should install macOS and get you to a setup screen—once you're there you could disconnect the Ethernet and try to set up the device. If it never gets to that point though you might need to try a restore through Apple Configurator.
完成的
@zpl -- I did have the Ethernet cable connected the entire time, however, it simply "reboot" and goes to "internet recovery" page again after selecting "Erase this Mac" and "Yes" to confirm that operation. Then it goes to that activation screen again. So, I didn't see anything for OS install or setup page at all. Should I disconnect ethernet connection right after selecting "Erase this Mac"?
完成的
显示更多的1条评论
添加一条评论
If you have access to another Mac system I would just create a bootable OS installer USB-C thumb drive with the OS you want to use (what Apple lists as supported) then just use this drive. It’s quicker and if you have a weak WiFI or internet connection which is likely why you got the error as the system couldn’t sustain the connection.
这个答案有帮助吗?
得分 0
2条评论:
@danj — I do have a bootable usb-c drive created in the past, but this laptop won’t boot from external drive at all. I guess there might be some security settings were set in the past. Any thought?
完成的
@lovecd - Review this Apple doc as you can see there is a double whammy! There can’t be an iCloud lock on the system and the tighter bootup setting needs not to be set. Apple Security
But the OS on the external needs to be the correct version for your Mac as well.
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 36
过去 30 天: 163
总计 963
