跳转到主内容
Repair guides for cell phones by manufacturer Nokia, including smartphones and a wide variety of the iconic "brick phones". This category is for phones not using an Android or Windows operating system.
520 个问题 查看全部
Nokia 2310 strange charging issues with new battery types
Ive got a 2310 which ive tried charging a HMD global made BL-5CB battery with a ACP-8E and ACP-7E charger, which displays a stop sign and the "Not Charging" text. Ive also tried it on some other nokia phones, some of them charges the battery as usual, some stop the charging and display the same text as before. How could i maybe solve the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @alex22265159
What is the model number of the original battery in the phone that presumably charged OK before it needed to be replaced?
Have read that the battery model used in the phone has to be replaced like for like e.g. phone that uses a BL-5CB battery won't charge a BL-5C battery, phone that uses BL-5C won't charge BL-5CA, even though it will work with all 3 batteries if they're already charged.
这个答案有帮助吗?
得分 1
6条评论:
ive used many different types of nokia made batteries on the device before so i sadly do not remember, but i guess maybe a BL-5C. The same battery also charges on a 2600, but refuses to charge on a 1110i
完成的
@alex22265159
I suppose the only way to know is to try a BL-5C and check if it charges OK on the 2310 phone as well as all the other Nokia phones you tried where the BL-5CB charged OK on some but not on others.
The only difference between the 3 battery models seems to be the capacity so perhaps this is checked somehow by the charging circuit idk
完成的
@jayeff alright, will try it
完成的
@jayeff the BL5C battery that i tried worked well on all phones, the new BL-5CB when plugged in started to beep the charging connected sound and flash for less then a second again and again until i pulled out the charger on my 1200 and also refuses to charge the battery
完成的
@alex22265159
If the BL-5CB was new then hopefully you can get a refund on it as it is not compatible with certain models that you have, unless you keep it for the models where it does charge OK
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Alex 222 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 25
总计 25
