When you lifted up the logic board to connect the thin lcd cable, you probably ripped the power/volume flex cable. This is a common issue. To confirm, under a magnifier (or jewelers loupe) look at the cable that connects the power button, it will probably have a tear in it.
If so, you'll have to replace the power/volume flex button, which requires soldering the cable to the new board. Without soldering experience, and the proper equipment, you can easily get into a bigger mess such as lifting off the solder pad on the board.
When I started offering iPod repairs, early last year, I dug myself into a hole a few times ... so don't let it get you down.
If you don't have soldering skills, I suggest you may want to find a shop that specializes in iPod repair.
1条评论
It's sad guys, I wanted to sell it but now it seems it is not someone wants to buy ..
Approximately how much can cost replacement of the cable?
Thanks for your help as I understand it is a fairly common problem but when I replaced I did not know about it ..
由 Farmax7 完成的
