跳转到主内容
加入维修社区 - 创建账户
Xbox Series S是微软于2020年11月10日发布的轻巧纯数字游戏主机,与性能更强的Xbox Series X同期推出。本页面包含Xbox Series S的维修指南、拆解信息,以及故障排除。
Why are all 3 usb ports dead
None of my usb ports work on my xbox series s. I've reset and everything
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
19条评论
Yes all three. If I out batteries in my controller and and plug it into the usb port it does like a buzz buzz vibration every like 30sec but it's constant if that makes sense. But it sucks bc I can't use external HD or anything.
由完成的
Hi Steven! I'm afraid that the USB IC need to be replaced on the motherboard to get your USB ports back to working.
由完成的
Well that sucks. Just bought it from a pawn shop
由完成的
Do you have any soldering skills? If not, you can bring it to a local repair shop and ask them to do the repair for you!
由完成的
Ehhhhh not really I used an originak xbox one to practice and it didn't got too well but I have a whole series s taken apart bc the hdmi port and traces were messed up and then I got the one I use now.
由完成的
显示更多的14条评论
添加一条评论
3个答案
最有帮助的答案
Hi Steven!
So all of them are no longer working? Then it must be the USB controller on the motherboard which required to be replaced.
这个答案有帮助吗?
得分 3
2条评论:
Anyway to reset it to maybe get them back right??
由完成的
Im afraid not… is everything up to date..?
由完成的
添加一条评论
@stevengeorge @dan0 looks like U407 got a "bit toasty". U407 is a TPS2001D USB power switch in a SOT23-5 package. It is available at mouser.com as well as digikey.com and many other places. Hope that is the one you both were referring too. Just in case, the capacitor just above it, is C1701 which is a 0.1µF 10% 25V capacitor in a 0201 package.
这个答案有帮助吗?
得分 2
1条评论:
Hey @oldturkey03! Yes I agree. Looks like that one need to be replaced. Thanks for sharing the picture! I would start with those first.
由完成的
添加一条评论
I found an answer to this problem, you just need to do a jumper between pin 1 and 5!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steven George 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 32
过去 30 天: 128
All Time: 3,438
