跳转到主内容
Repair guides and support for your LG TV.
LG OLED55B16A doesn't turn on, status LED off as well
Hi everyone,
I need help diagnosing a problem with my LG OLED55B1. The TV stopped turning on and there's no response from the status LEDs either.
I left it unplugged for several days but nothing changed when I plugged it back in, and I also tried resetting by holding down the ON button.
I found the service manual to test the power supply:
https://www.manualslib.com/manual/307899...
All the pins on P201 are okay except 12VT_ON which is at 0V. This value should be 7.8V in standby mode, right?
Is it possible to jumper connectors to simulate turning on the power supply and check this value? Or do you have any idea what else I could test?
Thank you for your help, I really want to be able to fix this TV which is 2 and a half years old and avoid having to buy a new one!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @arthf
You said "All the pins on P201 are okay except 12VT_ON which is at 0V", are you saying that you're measuring voltages on the other nominated pins on P201?
If so, just wondering how if the TV doesn't turn on as usually there's no other voltages present in standby mode, except the standby voltage as the power board hasn't been turned on by the mainboard, unless the TV is on but there's no power light and no noticeable activity i.e. no display and no audio
But yes, in standby mode there should be 7.8V on the P201 12VT pin only
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ArthF 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 36
