跳转到主内容
Samsung Tablet from 2021. The model number is SM-X200 or SM-X205
I spilled water on my tablet.
I spilled water on my tablet, and it wouldn't turn off for 3 minutes, so I had to power it off. I left it in my room, and my AC is broken so the house is 90 degree fahrenheit. What do I do next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @albert77027
What is the model number of the tablet?
In the meantime do not attempt to turn on the tablet or to charge it as this will only cause more damage than what there already is.
Knowing the model number will help to give you a better answer as to what exactly needs to be done to hopefully fix it and get it working again i.e. how to open the tablet, how to clean it correctly etc.
这个答案有帮助吗?
得分 1
6条评论:
I do not know the model number, but it's samsung galaxy tab a8. My tablet is still off and not charge
完成的
@albert77027
You will find the model number on the back cover of the tablet, near the bottom.
It should begin with SM-T??? or SM-X???
There are a lot of Galaxy A8 models so knowing the exact one will help to find the correct parts if any replacement parts are needed.
完成的
it have been 20 days, and my tablet is working fine now.
完成的
@albert77027
I would still check if the LDI is indicating that water entered the tablet or not.
You may have been lucky but if the LDI shows that water has entered the tablet then it will eventually fail. Maybe not soon but ......
完成的
@jayeff The LDI is fine and show no indication.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Albert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 93
