跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
222 个问题 查看全部
iPhone to iPhone 4 - 4S buildover
Has anyone of you guys had experience with building over an old iphone 2G to a later model?
I was thinking about doing this because I have an old iphone 2G and also the innards of an iphone 4 and 3G and it would be really cool to get it working :) because I really dig the iphone 2G design, never really liked the 3G and 4 outside look.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
remmeltbeckers, going to be tough, the connectors will be different, so the LCD/digitizer is not going to work. The 3 and 4 display will not fit your frame etc. So as you can see this will definitely require some heavy duty engineering.
这个答案有帮助吗?
得分 1
1条评论:
the 2g has a fatter case so it should all fit, just depends whether you can get the LCD from a 3 or 4 to stick to the rear case/antenna cover..it used clips instead of the 2 screw attachment that the 3 and 4 use. I think I'd try and "bodge" a whole new case to look like the old one instead of trying to work on a true case. The 4 uses screws to keep the LCD to the midframe so that's an extra headache. Maybe the 3/3gs would be easier?
完成的
添加一条评论
添加你的答案
remmeltbeckers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 845
