跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Digitizer not functioning well.
iphone4 16gb stop responding to touch after talked on the phone. it was working well before i listened to call for near about 40min. after disconnecting the call touch of phone not working. i restored the phone 2 times. check the internals . nothing found out. changed the screen 3 times from the market and 1 from the working phone. touch of this phone is working in another phone but not in this phone. i takes out the logic board and remained un contacted from battery for 30 mins but still same . logic board looks fresh. phone never opened before. i checked only. help.........
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
First, this is going to need a new display assembly. If that doesn't work, then it's the motherboard in the phone, or simply a defective replacement. Get another one if this is the case to confirm.
iPhone 4 屏幕总成更换
Should this be the motherboard, don't bother fixing it. The boards cost more then a phone and you have to be careful, since some of them are IMEI/ESN blocked. You can't verify a lot of these, since some sellers don't know or evade the question for obvious reason. I wouldn't bother.
They can also cost more then the phone is worth at times.
这个答案有帮助吗?
得分 1
5条评论:
i changed so many . the problem is in the logic board . have any idea ? i found 2 chips are responsible for this but very hard to get that .
完成的
You need to know compoent level soldering, whicj is that tough
完成的
yup i will try with that . otherwise last option is to replace the logic board
完成的
like I said, you need to compare the cost and find the best deal, DO NOT buy used boards due to the IMEI block risk, only time you do is if you get a cracked 4 on craigslist and it is not stolen, and the IMEI is clean and checkable
完成的
Here in india apple is replacing the phone on chargeable basis. i will go there becoz they are giving a new phone. then thats it the better option.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,831
