跳转到主内容
加入维修社区 - 创建账户
Uses a smaller heatsink and a user-screwable stand.
Why do I have no signal when my hdmi port isnt broken?
I have taken apart this ps5 to change the liquid metal and when I did now there is not signal. Here is a picture of the port:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Try and boot it into safe mode, if that doesn't work you might have forgotten to reconnect something when you put it back together again, might be worth opening it up and checking for anything damaged or missing.
这个答案有帮助吗?
得分 1
3条评论:
It wont even show anything in safe mode. Do you know of anything specifically that could be unplugged that would allow the hdmi not to work
完成的
I've never taken a ps5 apart, but talking about electronics in general it's so easy to forget to plug something in, or damage something unwittingly
完成的
I really appreciate your help but I need to find something specific I looked through the Ps5 5 times and haven't found anything.
完成的
添加一条评论
you should check the monitor/tv for any problems with the port or check your wire for any damage and also check that no pins for any ports are missing
这个答案有帮助吗?
得分 0
2条评论:
Ive done all of that and still nothing
完成的
Did you check the Panasonic chip?
完成的
添加一条评论
I am having a similar problem with a PS5 i am repairing. i have also check HDMI port and the Panasonic chip still nothing. Im not sure what else to test to see if the problem can be fixed. i know its not the tv or the HDMI cable, i have used them on other repairs and it works fine. any help would be amazing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Flixx 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 37
总计 477
