跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
464 个问题 查看全部
I detached the small clip for the ribbon cable. What now?
I detached the small white clip that holds one of the ribbon cables for the top screen.
I used some electrican tape and did my best to insert the ribbon in its slot. But apprently this isn't enough as the top screen turns on but gives no output.
What else can I do?
The broken clip
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You are probably going to need to replace it. If you are comfortable soldering then I would suggest doing it, and if not see if you can find a repair shop to do it. You'll probably need to use hot air.
Have a great day!
这个答案有帮助吗?
得分 0
2条评论:
@albertg87002 With replace it you mean the clip or to solder a new socket? The clip at first just detached itsself, so I tried my hardest to reposition it, but doing so eventually fully broke it.
I've unfortunately never soldered anything, nor I would feel comfortable for my first resolder to be something with solder point that small. I think I'll look for a repair shop when I can to have it replce it without discarding the whole motherboard, if they still exist. Thanks you! I wanna wait in case there are other answer before I select yours as accepted, I am a beginner afterall!
完成的
I do not think you can buy just the clip, so you'll need to replace the whole socket. I hope you can find a shop to do it! Let me know how it goes!
完成的
添加一条评论
添加你的答案
Sergio Mari 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 47
总计 47
