跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
464 个问题 查看全部
2 Things, a screw that is VERY stripped/ Missing charger port 3DS
The metal sleeve around the port that holds the charger in place is gone, but I can't get it open because a stripped screw that is in a slot is holding it closed. Also a 3DS.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ifixit has a guide on removing stripped screws, so start there. As for the charging port, I'm not entirely sure what you mean by 'metal sleeve', but it sounds like you'll need to replace the port
Replacing the port is pretty easy, but does require soldering. Take the motherboard out with this guide, desolder and remove the old port, and solder the new one into place
Nintendo 3DS Motherboard图片
指南
Nintendo 3DS Motherboard Replacement
难度:
困难
3 hours
Electronics图片
指南
如何卸下滑丝的螺丝
难度:
中等
5 - 45 minutes
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Okmkcashew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 27
总计 29
