跳转到主内容
Why is my 2011 MacBook Battery dying so quickly?
I ordered a new battery from ifixit for my early 2011 13 inch MacBook Pro, it has been dying within 2-3 hours of use and I am wondering why.
Update (05/19/24)
I can't seem to put a screenshot in here, but this is what it says, charge percent is 56% and current charge is 3199 mAh full charge capacity is 5728 mAh design capacity is 6000 mAh has 6 cycle counts battery status good manufactured at 2024-03-09 temp 28.4 Celsius, discharging with 3.08 watts.
Update (05/19/24)
heres the screenshot
Update (05/21/24)
Update (05/22/24)
Here is the screenshot at 100% charge
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
13条评论
@jude85858 - It looks like the battery just hasn’t gotten enough time to charge fully. Did you calibrate it follow the procedure outlined?
完成的
I calibrated it by following the card that came with the battery. Charge to 100% and wait 2 hours and then use until it dies and then wait 5 hours and charge it to 100% again.
完成的
@jude85858 - let it charge over night and check things again.
完成的
I charged it overnight and it is still dropping percentage pretty fast
完成的
@jude85858 - Can you post a snapshot of CoconutBattery so we can see things
完成的
显示更多的8条评论
添加一条评论
3个答案
最有帮助的答案
Please install this gem of an App CoconutBattery is will allow you to see what’s happening and post a snapshot of the main window here so we can see as well. Then we can guide you to the next action.
这个答案有帮助吗?
得分 1
1条评论:
Sorry I am taking so long to respond, I have been busy and will tell you what is happening with the battery sometime this weekend.
完成的
添加一条评论
It almost sounds like the battery you got from iFixit is bad. Do you still have to original battery? Could you pop it back in and see what happens?
这个答案有帮助吗?
得分 0
6条评论:
I do have the original battery, I will put it back in and tell you what happens.
完成的
just put the old battery back in, on coconut battery status says check battery has 830 cycles but the computer still works. It is losing charge around the same rate as the new one. it is at 13% and activity monitor says it will die in 12 minutes.
完成的
Also it says discharging with 23 watts, a minute ago it said 30 watts. The newer battery was reading around discharging with 8-10 watts. I don't know if this means anything but its something I noticed.
完成的
Nevermind I think that is normal
完成的
@jude85858 - Okay, your original battery is draining at the same rate as the replacement. Here's the action to take:
Quit any apps that you are not using and let the battery drain slowly. Set the screen to never sleep in the energy saver pane in System Settings (System Preferences), and disable the screen saver. Once it drains, then vigorously calibrate it (that's just what I call it). Charge it to 100% WITHOUT ANY PROGRAMS RUNNING, and leave it plugged in for 2 hours. Then, try playing 4K / HDR / 60 FPS videos. You can find these on YouTube without too many problems. Play this until your Mac shuts down. Do not let the videos stop playing. (To make this process even more accurate, try running many applications at the same time. Open Photo Booth to operate the camera. Keep the Activity Monitor update frequency at very often. This will drain the battery very quickly. Then, leave it drained overnight, and charge it to 100% WITHOUT INTERRUPTION.
完成的
显示更多的1条评论
添加一条评论
When I calibrate a battery as mentioned above, I also delete the 3 files found in HDD library Preferences .com.apple.power*, empty the bin, then restart, these files will then be written fresh in case they are confusing something.... seems to help especially to reset the service recommended notice ;) hope that helps.
这个答案有帮助吗?
得分 0
5条评论:
thank you I will try this and tell you if it does anything.
完成的
@jude85858 Have it charged up as much as possible before doing it :)
完成的
@jude85858 & @livfe - Just so you guys know, com.apple.power files are so macOS understands battery information, power adapter information, etc. I wouldn't think that these files could be draining the battery, but it definitely is possible! I would recommended that you have a backup of these files before removing them, or else your Mac may crash at sleep, have an X on the battery in the menu bar, etc. Also, macOS will not like it if you are messing with the system files, so you'll probably have to turn off System Integrity Protection before you proceed. If something goes horribly wrong, it may cause you to reinstall macOS. Good luck!
完成的
@jadonlyon No need to disable the system integrity, they just fly to the bin!
On a reboot they appear to be freshly created by the system, I never had a problem doing it so far and it did seem to correct some 75% of SR's on batteries. So a new battery and these 'new files' I would think help the system to have only the info regarding the new battery in case they did carry over any previous info from an old battery. Worth a try at least.
完成的
@livfe - Definitely worth a try! You are absolutely right!
完成的
添加一条评论
添加你的答案
Jude 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 165
总计 165
