跳转到主内容
the Bluebird Sylphy G10 (N16) was sold as the Sunny Neo in Thailand and as the Sunny in Hong Kong, Kenya, Singapore, Sri Lanka and the People's Republic of China.
9 个问题 查看全部
Why does the 2005 Nissan Sunny vibrate excessively when slowing down?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi @omaralmelhem
Does it do this when applying the brakes or just taking the foot off the accelerator?
Does the steering wheel shake or is it the body of the car?
If the body is it in the front or the back?
完成的
it happens when applying the brake.
the steer didn't shake.
完成的
添加一条评论
1个答案
最有帮助的答案
Greetings,
The most common reason for a car to shake when slowing down is a warped front rotor. The best thing you can do to resolve this issue is to take the front rotors to a brake or tire shop or even some auto part stores and ask them to turn the rotors. They will use a special brake lathe to flatten the rotors back into specifications and the vibration should go away. Without further description this is the best guess i can give you. Alternate items that could also cause undo vibration when braking would be loose inner or outer tie rod or issues with bearings.
A failing tie rod end can be dangerous and continuous driving of the vehicle without repair can start to effect other aspects of the front end.
Cheers!!
Moe
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Omar Almelhem 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 5
过去 30 天: 32
总计 43
