跳转到主内容
The eighth generation of the Mitsubishi Lancer.
51 个问题 查看全部
change my turn signal, into LED's it does hyperflashing all the time
I haved change my turn signal, into LED's it does hyperflashing all the time How do can I fixed it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@calmaquianom how did you do the change? What do you consider "hyperflashing"?
完成的
添加一条评论
1个答案
最有帮助的答案
The vehicle is not seeing the resistance load it expects with an incandescent bulb with a LED, so it is acting like it has bulb out.
You ether need to add a load resister (https://www.instructables.com/How-to-Ins...) for each bulb, or there may be a turn signal oscillator (a module which flicks the lights on and off) which will work with LED bulbs.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Calma Quiano M. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 17
