跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Is this contact too damaged?
i'm taking apart a 3ds that looked absolutlely destroyed, despite this both screens worked (and yet they were all yellow and gunked up from an unidentified liquid, i'm guessing cola of some kind.) and every button worked, apart from the A button. So i removed the sticker, cleaned the contacts and at the moment they look like this. is this too damaged? should i not bother buying a new button dome sticker?
the contact won't clean more than this, at least not with isopropyl and q tips.
please let me know. i'm an amateur and i don't know if this is still salvageable, thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Enerd!
First things first! Regarding the first picture, on the left side there is corrosion as well! Please clean the whole motherboard with isopropyl alcohol.
Regarding the 2nd picture, you already did a lot to clean it. My guess is that a new button sticker will work and I would try this first. If not, you can remove the (new) button sticker and remove the rest of the dirt with a tiny flathead screw driver (be REALLY careful with this!!! Do not touch the traces, as they can be cut easily!). And after you cleaned it with the flathead, then use isopropyl alcohol again to clean it. Then after this, place (again) the new sticker button on it and test again.
I would definitely buy the new sticker button (2 of them just to be sure) to try. A new motherboard is rare to find and if you can find one, it's probably pretty expensive. Sticker buttons are pretty cheap and worth a try!!
I wish you good luck and let us know how it goes!
这个答案有帮助吗?
得分 2
2条评论:
Yup, i am aware! it needs some thorough cleaning, will do!
Thank you for your comment, i bought the stickers and i'm gonna wait on them for a bit since they come from china! i will update you then! Thanks again!
完成的
My pleasure :)! Hopefully you will get it back working again asap! That would be great! Thank you too!
完成的
添加一条评论
添加你的答案
Enerd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 79
