跳转到主内容
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
one of the USB C isn't working
I used 2 display monitors and had them connected to a multi connection bar. 2 days ago I unplugged the bar because I just needed the laptop by itself. The laptop was in sleep mode when I pulled the bar out. But later when I plugged the bar in and used my displays, they won't work, and I realized that the one USB C has failed on one side. If this problem cannot be fixed by doing something Non-Hardware, then please give me a step by step how to fix the USB C port.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The USB-C port assembly is replaceable! MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board
Sadly, it’s a bit of work as you need to lift out the logic board to get it out and the replacement in.
Replace one of the thunderbolt connector boards from the left or right side of your laptop.图片
产品
$14.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ashish Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 52
