跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
iPhone 4 does not sync/charge after home button replacement
I completely took apart my iPhone 4 GSM over the weekend and reseated the home button because it was not very responsive. The home button works perfectly now but I have managed to break something in the process. What i broke i am not sure of but i hope the great people of ifixit can help me out. :)
My iPhone 4 can no longer sync to computers at all. It also will not charge unless it is turned off or in sleep mode.
Things that i have tried so far
1. Different USB cables
2. Using wall charger/different computers
3. Hard Reset
4. Re-take apart and put back together
5. Clean all connectors with rubbing alcohol
6. Restore/DFU mode won't connect to PC
So far it looks like i might need to replace the dock connector. However, if it can still charge when it is turned off, would that make sense?
All replies will be greatly appreciated. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you check dock connector flex? May got damaged when disconnected. Dock comes whit speakers a mic for memos, do they work?
这个答案有帮助吗?
得分 0
1条评论:
I have checked the dock connector and it appears to be in working order. I cleaned the connector with rubbing alcohol to ensure no dirt/dust was giving improper contact. All input/output devices (i.e. speaker, mic, home button) are functioning normally so I doubt it's the dock connector. What else might be causing this?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 682
