跳转到主内容
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 个问题 查看全部
How do you remove the front door panel & sound panel?
Do you have a diagram of how to remove front door panel of 2001 Dodge Caravan to check the window motor ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
washkins59, try this" TRIM PANEL REMOVAL
(1) Remove the plug and remove screw attaching door pull cup to inner door panel.
(2) Remove switch bezel and disconnect power window/memory switch.
(3) Remove screws attaching trim panel to door from below map pocket.
(4) If equipped, remove window crank.
(5) Remove screw holding door trim to door panel from behind inside latch release handle.
(6) Disengage clips attaching door trim to door frame around perimeter of panel.
(7) Lift trim panel upward to disengage flange from inner belt molding at top of door.
(8) Tilt top of trim panel away from door to gain access to latch linkage.
(9) Disengage clip attaching linkage rod to inside latch release handle (Fig. 13).
(10) Separate linkage rod from latch handle.
(11) Disconnect the power door switch, courtesy lamp electrical connectors.
(12) Remove front door trim panel from vehicle.
Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
washskins59 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,434
