跳转到主内容
Ninth generation of iPad, released September 24, 2021, available in 64 or 256 GB models. Model Number A2602.
22 个问题 查看全部
How to troubleshoot a screen that isn't cracked but won't come on
How would I troubleshoot a screen that isn't cracked but won't come on. My son stepped on the back of the iPad. The screen appears fine. I was able to gently bend the edge back to flat but there is a slight depression on the back (left side facing screen)maybe something came loose. Maybe I need a new screen or back or some other component. I'd like to know what I might need to take apart and put back together and to diagnose what isn't obvious.. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Brian,
Generally the best indicator that the screen needs to be replaced would be if the iPad seems to be working in other respects.
For example, does it respond when you plug it in, via a chime or vibration? Does it do anything when you power it on, again like a vibration or a sound? Is it recognized when you plug it into a computer? After it turns on, does it seem like the touch screen responds (I realize this is tricky without a display)?
If you can get it to respond to you like it would with just a blank display, then it strongly indicates the LCD has been damaged and needs to be replaced, and that will most likely get you going again. LCD displays are made of very thin glass and can crack very easily. In addition, there are a large number of flex cable connections bonded to the glass itself, and those can get dislodged as well. Either of those conditions will kill the screen and the only fix is to replace it.
iFixit has a guide giving you step by step directions on how to do that replacement here.
iPad 9 LCD Replacement - iFixit Repair Guide
Assuming you can get it to display some signs of life, then this is your best bet. The good news is that most LCD vendors will let you return the display as long as it hasn't been installed. This is easy with an iPad as all you have to do is plug it in, reconnect the battery and see if it's working. If so, continue on and reassemble it and you're done; otherwise just unplug it and you can then return the LCD for a refund.
Of course, if there are no signs of life, that is a whole different issue and would probably need to be evaluated by a technician to determine the cause. There are, however, a lot of very good technicians who frequent this forum who might be able to help if that's the situation you find yourself in, so check it out and let us know what you find and we can go from there.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 60
