跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Battery wont charge after battery replacement
My battery replacement arrived today and i follow the instruction to replace the battery. I have ensure that every ribbon has been connected and has double check before putting it back together. The phone would turn on and show a low battery screen. I try restoring the iphone but that didnt help. The phone would not charge at all. I try to plug it in a different computer and it still wont charge. Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You may have just received a bad battery. Take out the new one and replace it with the original and see if it does the same thing. If it doesn't then you can pretty much assume you received a defective battery. It happens all the time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sor2y 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 876
