跳转到主内容
修复你的物品
维修的权力
商店
三星数码相机的维修指南和支持。
426 个问题 查看全部
I applaud your initiative!
3/28/2012
" YOU GUYS ROCK!!!!!!"
I'M 85 YRS YOUNG, LEARNING FROM YOU YOUNG FOLKS STILL.
I have a Samsung camera I really enjoy using, no cost to develop the pictures etc. I have had it about 2 years. ( SL30 ) The LCD monitor has bit by bit turned black. The picture are still great , but I can not aim correctly as the subject I am shooting can not be seen.
From research on the computer, i understand THIS IS A RECURRING HAPPENING, WITH THE Samsung CAMERA. I SEE NO WAY TO DISMANTLE MY CAMERA. HOWEVER, (I HESITATE TO USE A SLEDGE HAMMER AT THIS POINT.)
My Mother taught us before discarding anything , if it was able to be fixed, You learn from trying, So we took it apart. Some times we could not reassemble it. some times we could. Those times were very rewarding and we did not have to spend money for a replacement.
So, Mr Fix its, Can you tell me how to clear up the LCD monitor?
Good luck I hope this idea catches on.
there is way to many things ( stuff )_ being thrown out to the dump. That could be repaired. If we could get a class started in every high school in the UNITED STATES, we would have a lot of kids tinkering with fix it projects , and off the streets 9 get them interested in other things.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
最有帮助的答案
Janet Evans Laury, Welcome to ifixit :-). To get to the point, I do believe that you may have to change your LCD, since the problem started gradually. You may want to disassemble it, and have a look at replacing the LCD. You can save the attached images and print them out, may be hard to see on here. The part number for the LCD is AD07-00097A and it is available at places like this http://www.partstore.com/Part/Samsung/Sa... Let us know if you need more information. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Janet Evans Laury 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,500
