跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2431 个问题 查看全部
Will not power on, what could it be?
TL;DR iPhone 4 will not power on. Logic board is verified working, battery is verified working and charged, dock assembly is verified working.
So here's the deal, I got this dead iPhone 4 for doing some trade work. I have tested the logic board in my own phone, as well as the battery and the dock connector. I cannot, for the life of me, think of anything else it could be. All of these parts work when they are put in my phone but when I put them back into the dead phone, nothing happens. It doesn't charge, it doesn't turn on, and the computer doesn't see it. What the heck could it be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
已选择的解决方案
In this phone remove all the jacks . just leave battery and dock connecter jacks with the logic board. then try with usb cable with pc. it will sure power up and iTunes recognize it. then slowly put the jacks back one by one to find out the fault. means first the put the only LCD jack . before this putting back make sure that battery to be unplug. slowly do this . after LCD put the digitizer jack then power button then front camera then back camera then side volumes buttons. then homebuttom. slowly you will find the fault then just change that part only. thnx best of luck...
这个答案有帮助吗?
得分 1
评论:
Thank you so very much! I was able to narrow it down to the proximity sensor/power button cable. I happened to have a spare cable laying around and upon removal of the old one I was able to see some corrosion on the sensors that wasn't obvious from the back side. I put the new cable in and put everything back together and it fired right up. Thanks again for the troubleshooting recommendation.
完成的
添加一条评论
Sir I owe you the life of my iPhone, Thankyou!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
magistry 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 3,723
