跳转到主内容
加入维修社区 - 创建账户
Repair and troubleshooting information for HP 15‑fc0000 series 15.6" laptops, a line first released in January 2023. Laptops in this series have model numbers beginning with 15-fc.
My HP 15-fc0037wm laptop won't turn on.
My HP 15-fc0037wm laptop won't turn on.  I have checked the power supply. I have replaced the battery. I have removed the battery, plugged in the power cord and held down the button down -- no results.  When I press the power button, the tiny light on the power button blinks once, then nothing. When connected to power, light next to the power outlet on the laptop is on. What am I missing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @johnnyray,
Try disconnecting the power adapter, removing the battery and then press and hold the power button for 30 seconds and then release it. Reinstall the battery, reconnect the power adapter and then check if it turns on OK
完成的
Thanks, tried that, but didn't work.
完成的
添加一条评论
1个答案
Sounds like an internal problem. You have eliminated the battery and maybe the adapter. You need to verify the adapter plug has the specified voltage on it either by measurement or substitution.
Replacing the battery should have powered it on. Most batteries are shipped with at least 50% charge.
The blink of the button LED is telling me there is an internal short and the power module is disconnecting as soon as it detects that.
It could be anything, but a shorted CPU is not uncommon.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Johnny Ray 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 228
