camera wont turn on!
i need help my camera wont turn on i replaced battery and charger and still wont turn on when i bought it it worked then i stored camera for about a year then i try to turn on and it wont
Start of with making sure that your battery contacts are all clean, that there is no corrosion or debris present. You may have to disassemble the camera to get to the contacts. I would also make sure to change the Lithium battery at component side of Top Operation PCB. Once you have the contacts cleaned and the battery makes good contact, reevaluate. It is unlikely that you have any damage to the flex or the PCB from just storing the camera.
UPDATE
There are two fuses on your PCB that you could check. Use a multimeter and check for continuity.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 3,486
