跳转到主内容
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
I Swapped the Trigger and Bumper Ribbon Cables
I swapped the Trigger and Bumper Ribbon Cables with new ones and now the controller doesn't power on. If I disconnect one of the t&b cables (L1/L2) and leave the other one plugged in (R1/R2) the controller powers on and R2 and R1 work. I'm confused as to why this happens. Any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
What if you disconnect the R1 & R2 cable? But leave the other one connected, does it still power on?
完成的
No it does not
完成的
Any solution??
完成的
添加一条评论
1个答案
最有帮助的答案
Have you doublechecked that the triggers match up with the points on the controller responsible for registering input? If not do that.
There should also be a spring in the buttons. Is this connected correctly?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Benji Customs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 97
