跳转到主内容
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 个问题 查看全部
Ds doesn't turn on but bottom screen flashes white!
So a few days ago my DS was sitting on my bedside table which is 50cm from the floor, it was charging and my clumsy self tripped over the charger cable and the DS fell to the ground
The next day I went onto the DS I tried to turn it on, the blue light appeared and then suddenly it makes pop sound and the bottom white screen flashed and then it turned off.
Can anyone tell me what to do? I've heard it may be a problem with the ribbon cable but I'm not sure, I'd appreciate any kind of help 😊
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
That pop sound is usually from a damaged or unseated cable. It could be any of the connectors on the board, but usually its the display. You can try opening it up to check the connections, but if those connections are good, then it could be damaged displays which can also cause popping.
I would also double check that the unit can charge (Shows charging light) and that the connector on the board is solid.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nix_Pix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 17
