跳转到主内容
2015款 Nintendo 3DS XL,也被称为新 Nintendo 3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
'New'/3DS XL Battery Calibration
Howdy.
Just ordered a battery from the website's store. I noticed the instructions for the procedure of calibrating the new battery that are on the item's page. For the first step, it says to charge the battery to full and then to let it charge for "at least" another 2 hours before moving onto the next step.
What is the longest amount of time past 2 hours from when it's fully charged that I could continue charging it to get the most benefit out of that step? I'm also curious what calibrating the battery properly actually results in afterward compared to a battery that hasn't been calibrated properly.
Like, for example, does the new battery end up holding/carrying a longer charge, etc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Charge it full. Run it until it red lights and shuts itself off, recharge to full with it powered off. Do this 2 or 3 times. This is "battery calibration" or "training" procedure.
这个答案有帮助吗?
得分 1
14条评论:
Just curious, why do your instructions differ from the instructions given on the item's page?
And just to make sure I understand your instructions, you're saying I alternate charging it to full while using the 3DS, and charging it to full with the the 3DS powered off. Repeat two or three times. Is that right?
完成的
@junterchute Play until it dies. Then set it to charge. Then when it's done charging, power on, play until it dies. Go through this process from start to finish 2 or 3 times. This way the 3ds will "learn" what a "full" and an "empty" battery is with regards to this new battery. This is pretty standard procedure for lots of devices using lithium batteries.
完成的
@rebtech Okay, thanks for clarifying what it does. Makes sense. I assume it'll come with some charge in it, then? So the first step is to use up whatever is in there. After it's dead, then I go through the loop of charging it to max and draining the battery entirely 2-3 times.
完成的
@junterchute Yeah a "new" battery should arrive either at what's called "storage charge", or full. This ordeal applies to other things as well like cellphones and laptops. Yup you have it right.
完成的
@rebtech Last question I have: when the battery is drained, I've heard it's a good idea to make sure it's completely drained by turning on the power afterwards several times until the 3DS doesn't turn on at all. Would you advise that I do this before each recharge during the calibration?
完成的
显示更多的9条评论
添加一条评论
@junterchute I mean, just wait how long the battery lasts by putting it on standby and starting an timer, now do that with the og/the battery that came with the 3ds originally, should see the difference.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
J Unterchute 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 70
过去 30 天: 347
总计 5,083
