跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Orange light turns on for a couple of seconds but 3DS doesn't charge
Less than a year ago I fully charged my old 3DS (after not touching it for a couple of years), using the original cable. Today I wanted to charge it again but the orange light only comes on for a couple of seconds, then turns off. I left it plugged in for a couple of hours but the 3DS still won't turn on.
People recommend to remove the battery, press the power button for a couple of seconds, then put the battery back in but it still won't charge. The battery looks fine, not bloated.
I found this thread about someone who looks like they had the same problem but I don't quite understand what they did to fix it. Did they plug the 3DS in, then remove the battery, wait a little bit and put the battery back in or do you unplug some time inbetween too?
Is there anything else I can try before I buy a new battery (I don't think you can buy the genuine ones anymore, can you?)?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi, This can be a dead batteries because your indication on what the console does is the same as if there were no batteries in the console, if you have you can check wis a multimeter if your batteries charge or not, before replacing it i well check that the connection this does well between the batteries and the pins connecting your batteries to the motherboard the problem is that it can also come from the charging port in bulk your batteries still has a small amount of power but your port does not charge it wis the power supplied to the batteries, to run the fastest option is to change batteries(it is no longer possible to find official nintendo on the market, or they are priced at a console in good working order and have no guarantee of functioning, the unofficial therefore its best option, (if you buy an unofficial one, check and take one with a good amount of reviews confirm their good functioning (some sellers store their battery for too long and do not check whether it works or not before sending))
Ps: In the thread you have linked the guy recommend to have unplugged the battery and the charging cable press the button for maybe 30sec to 1min, put the charging cable maybe 10sec to 30 sec and put the battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neph 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 31
总计 491
