跳转到主内容
加入维修社区 - 创建账户
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
Can't remove thumbstick domes, they just spin. What's going on?
I'm trying to replace my bumper switches, but I need to take off the thumbstick domes to do that. I can get them to spin clockwise or counterclockwise, but they do not come off, no matter how much I rotate them. I tried the tall thumbstick, a wrench, a socket screwdriver, and even my drill, but nothing can get the thumbstick domes to unscrew. Any suggestions as to what's going on and how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
如何修复 Xbox One Elite 系列 2 控制器中的模拟摇杆漂移
Look at Step Ten , open the 16 comments linked directly below that step, and read the comment on the first one by Matt Bolek.
这个答案有帮助吗?
得分 0
添加一条评论
There is no fix. The thumbstick dome is supposed to thread onto the part that gets soldered to the board using a very course thread. However, if you find the dome to spin, with grinding, then that means the thread snapped off inside the dome.
https://www.ebay.com/itm/126446155464
Look at the pictures and one picture has a dotted circle circling a broken thumbstick. That is what happened to you.
Unfortunately the only thing you can do is replace the entire thumbstick assembly or the controller.
这个答案有帮助吗?
得分 0
添加一条评论
So I had this problem and I got them off by using a needle nose pliers and turning them. If yall need to ask me for a video of me taking them off my gmail is
rallymarliere16@gmail.com
这个答案有帮助吗?
得分 0
添加一条评论
This problem is usually due to an attempt to aggressively unscrew the dome from the stick. The dome is held onto the stick using an adhesive (something akin to Locktite) that is supposed to keep the dome from unscrewing during normal use. Users can attempt to unscrew the dome using the longer thumbstick option available in the accessory pack. When attempting to unscrew the dome using this method, do not twist with a lot of force. If too much force is applied the stick itself may break inside the stick housing, leading to the the issue the OP is having. If the stick does not twist off fairly easily, then use a hair drier or a hot air station set to low heat (120C or lower) to warm the dome, and also loosen the adhesive. Then twist and it should release and twist off.
If the stick is damaged due to over-torquing the dome, it will need to be replaced. In that case, follow the guide available on ifixit. The part can also be acquired form ifixit or Microsoft directly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Phil J 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 175
总计 3,272
