iPhone 11 earpeice doesn't sound right after replacing battery
I replaced my iPhone 11's battery following the guide here on iFixit. For the most part, my iPhone functions normally. However, the earpiece sounds distorted. Why could this be?
I just figured it out! I just realized that I didn't fully reconnect the earpiece and front sensor assembly cable when I sealed the device back up. I opened the phone back up, pushed the connector into place, and the earpiece works fine now. :)
So for anyone reading this, before you seal your device back up, power it on, test all the functions of your phone, and make absolutely sure everything works, and that all connectors are pushed fully into place, so that you don't end up wasting a set of adhesive strips like I did.
这个答案有帮助吗?
Great, glad you managed to get it sorted 👍🏻
Could the flex for the earpiece have been damaged during the battery replacement?
这个答案有帮助吗?
Is there anything else that could be causing this issue?
To be clear, my Face ID still works fine, but my proximity sensor does not.
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 14
总计 64
