跳转到主内容
Repair guides and disassembly information for Asus Republic of Gamers laptops.
352 个问题 查看全部
My asus laptop won't power on.. when put on charge, it indicates its c
My asus laptop won't power on.. when put on charge, it indicates its charging but won't but when I power it on it won't come on.
What can be the possible solution?
Ram dead?
CMOS battery dead?
ASUS ROG G551JM
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @redeemgrimm
Try a power reset and check if that resolves the problem.
Disconnect the charger and then remove the battery from the laptop.
Then press and hold the power button for 30 seconds and then release it.
Reinsert the battery and connect the charger and check.
If still no good it may be the RTC coin cell battery (aka cmos battery). The problem with this is that this battery is located on the underside of the motherboard. (click on 2nd smaller image on left side of main image to see the CR2032 battery lower left side of board in image)
To access it you will have nearly completely disassemble the laptop. Once you have removed it from the board, measure its voltage. If it is <2.4V DC or is >5 years old, replace it. These batteries are commonly available everywhere e.g. supermarkets.
By the time you have accessed, removed/replaced the RTC battery and reassembled the laptop, the BIOS would have been reset so once the laptop is completely reassembled, connect the charger and check if it turns on.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Redeem Grimm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 29
