跳转到主内容
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 个问题 查看全部
Why won't my DSi XL turn on, and only give blinking orange indicator?
I have a DSi XL that won't turn on, and only give a blinking orange light. When the power button is pressed, blue light along with both screens flash for a split second. I have tried new batteries and checked for internal problems, but everything looks fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Here's some things to try:
  1. Make sure the contacts on your board for the battery are not corroded, bent, etc.
  2. Try re-seating the original battery, you may not have put it in properly
  3. Use a multimeter on the battery, make sure it has ~3.7 volts
  4. Use a multimeter on the R1 fuse to make sure it isn't blown, it won't be visibly detectable
If the battery has the wrong voltage, that could be the issue. If the R1 fuse is blown it will need replaced, or bypassed with a wire, small piece of tin foil, etc.
这个答案有帮助吗?
得分 1
2条评论:
Is the r1 fuse on the motherboard, or the power board? Also, do you think replacing the board that has the problem will make the DSI boot? The DSI has no games or data on it.
完成的
The R1 Fuse is on the motherboard, if you look at Step 13 on this DSi XL Motherboard Replacement Guide you can get a good view of the R1 Fuse (it's to the right of the Card Slot, it is labeled on the board as well).
Personally I would try to bypass the fuse and test if it will boot before I tried replacing the whole motherboard. You don't need solder or anything to bypass the fuse, just tape a small wire or a small piece of tin foil to either side of the fuse and see if it boots from there.
完成的
添加一条评论
添加你的答案
LucaBadooka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 70
