第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3267 个问题 查看全部
The battery charge indicator is lying!
My iphone4 is switching off when indicator say about 40-45% of charge and show the empty battery logo then I'm trying to switch it on. What is wrong? Is it time to bury the battery?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
certainly sounds like it. Once the battery starts failing suddenly or emptying rapidly it's time to swap it.
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
2个回答
已选择的解决方案
The battery is rehabilitated. The problem was solved by restoring of factory defaults. iOS bug, I think.
这个答案有帮助吗?
按维修分数 1
添加一条评论
Another fix for battery memory problems is full drain & full charge a few times. & hard reset.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Serj 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 5,038
