跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
216 个问题 查看全部
using USB wi-fi adapter to connect wireless network
MY question is:
if I remove the wi-fi network card inside of my iMac, can I use any USB dongle to connect the wi-fi of my home network?
I want to remove wireless card cause I want to use miniPCIexpress slot for other purposes
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
you need one compatible with OSX.
I have this : http://www.amazon.com/gp/product/B002RCK...
for a similar problem, but not the same.
I do, or did have to use this on a older OSX based computer running 10.5..... i did have to use the little OSX airlink tool/program rather then built in airport to control it.
Not sure if this works with snow leopard or lion.
something to look into or maybe point you in the right direction, or look for more reviews etc..... i don't have latest info for wireless for mac since this worked fine for what i was doing at the time.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joleisa 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,821
