跳转到主内容
Repair documentation for the updated Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1A
27 个问题 查看全部
Headphone port removal and replacement
Hey does anyone have a video on how to remove and reinstall the headphone jack, I can see 4 solder points around it but my iron gets too close and just melt the plastics, same with the hot air gun. Any suggestions, thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Flux it, use "Low Melt" solder, and lower the temp on the iron. After a little time the port/jack should just fall out. Wick away the old solder, solder in the new jack using 60/40 leaded solder.
Wait......by "melts the plastics" do you mean the controller shell?? O_o
Always remove the board from the shell before hand. :)
这个答案有帮助吗?
得分 0
1条评论:
Hey thanks for the response. Not not the shell, I take the board completely out, I meant the headphone port plastic itself. I will try what you said. Thanks.
完成的
添加一条评论
添加你的答案
Jordan Shaw 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 72
