跳转到主内容
于2019年9月发布的中端手机。在中国和印度的别名为Redmi K20 Pro。 具有6.39英寸Super AMOLED显示屏,Snapdragon 855处理器,、27W快速充电功能、4000 mAh电池、屏下指纹、弹出式摄像头以及48 MP主摄加上13MP超广角镜头和8MP长焦镜头。
23 个问题 查看全部
Xiaomi 9t won't make or receive calls
Have done troubleshooting on all software and done a factory reset. I'm also able to make calls with the sim in different hardware.
Any suggestions what hardware needs to be investigated or replaced to fix this issue?
Note - mobile data and SMS still work, just not calls.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
There are several potential solutions to this issue that have been suggested by different sources. One of the most common suggestions is to check if call barring has been accidentally turned on. Call barring is a feature that blocks incoming and outgoing calls, and if activated, it can prevent any calls from being made or received1. It can be deactivated by going into the phone settings and turning off call barring. The default barring password, if required, is usually 1919
这个答案有帮助吗?
得分 0
1条评论:
I've tried looking at call barring options but it is not the issue.
完成的
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 63
