跳转到主内容
Won't power on, light blinking 3 amber, 1 white, bad coin cell battery
I've got an Inspiron 3593. It won't power on, the power light is blinking in a 3 amber, 1 white pattern, which per the service manual indicates a bad coin cell battery. I removed the battery, and confirmed it was indeed dead. I've tried two different new batteries, both confirmed good, and it still won't power on with the same 3 amber, 1 white blinking pattern. I've reseated the RAM and also removed the lithium ion battery to reset it, still won't power on. Any suggestions for further troubleshooting?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @henson79010
Try resetting the BIOS by performing a full power refresh.
Disconnect the main battery from the motherboard, remove the coin cell RTC battery from the motherboard, press and hold the laptop's power button for a full 30 seconds and then release it.
Reinsert the coin cell battery (+ve side up), reconnect the main battery to the motherboard, reassemble the laptop, connect the charger and then check if it starts OK.
Update (12/29/23)
Hi @henson79010
If the motherboard is a Compal LA-J108P/J109P here's the schematic.
The Power button is on p.77 top left of page.
这个答案有帮助吗?
得分 1
3条评论:
I tried that, no go. I borrowed a power adapter from a friend just in case mine was wiggy. When I plugged that one in, the white light came on solid, no amber blinking, but it still wouldn't turn on. I let it sit a bit and out of the blue it turned on the next time I tried. It went into the bios setup and I updated the settings. The bios setup showed my friend's adapter as working fine, so I plugged in the original one and it showed it as fine too? I exited bios setup, it rebooted and started reflashing the bios/firmware. I assume this was a recovery flash as I don't think there were any pending updates. After the flash completed, it rebooted, and turned off. Then didn't want to turn back on again, even though the power light was solid white still. Let it sit a bit, got it to turn on, went to check for dell updates, and it downloaded a bios update and wanted to install it. Let it, rebooted, it flashed, and then came back up ok. Now I'm letting it sit powered on until the battery is full before I do anything.
完成的
@henson79010
More for elimination purposes than anything else, check the condition of the battery and create a battery report
When you have the report compare the Design Capacity value versus the Full Charge Capacity value as shown by the report. For a good battery the values are very close.
Use the formula full charge capacity value x 100 ÷ design capacity value to see what percentage the battery is when fully charged.
完成的
36982/41998 = 88%
Not perfect, but the laptop is like 3 years old. Well, I installed all the latest updates, left it on until it was fully charged, and then powered it down. Now it won't turn back on again <sigh>. If I unplug and plug back in the power adapter, the white light comes on for a sec then turns off, which I think is expected when fully charged.
I wonder if the power button is busted? Hmm. Interesting. I was just staring at it angrily and it turned itself on. Now it won't stay off 8-/. Every time I shut it down, it turns itself back on within about 30 seconds. While it's on pressing the power button doesn't do anything, I'd expect it to sleep or ask to shut down.
Aaaaand now it's back to not turning on. Guess I'll take it apart again and try to test the power button.
Thanks everybody...
完成的
添加一条评论
添加你的答案
henson 将永远感激不已
浏览统计数据:
过去 24 小时: 20
过去 7 天: 115
过去 30 天: 495
总计 1,662
