跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Switch is not turning on. It's not the battery, dock or chord.
I was playing the latest Pokémon entry, and upon undocking my switch, the screen reloaded into an error which only displayed its serial number and instructions to forcefully power it off.
I tried to make it do anything else, but after giving up, I followed up the instructions, keeping the power button pressed for 12 seconds (It actually was 15).
Now, the switch is not turning on. I tried waiting, setting it charging, both on the dock and the wall, any combination of components (or lack of them), pressing it long or short times. Nothing happens.
Original switch dock's light does a thing not even OLED's does, when I place it in, the power light flickers for an instant. Nothing else.
I tried another switch with the same combinations, and they all work. The problem is clearly on the device.
I also tried one of these chords that tell you the voltage and amperage. Voltage is stable between 5.02 and 5.04, and I get a static 0.5 on amps, it doesn't change.
What piece do I have to replace to get it fixed? (Or please tell me any tests I can try. I got the right screwdriver, a multimeter and a soldering iron)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
I finally took it to a repairshop to see if they can even find out the cause.
They gave up on it, as the diagnosis I got was, "a short circuit in a bus between the port and the CPU"
完成的
The repaishop AND nintendo gave up before trying (They both told me they did).
But there's tons of videos in youtube fixing this kind of stuff, so due to the lack of people daring to try,
So I am on this site looking for leads so I can fix it.
完成的
添加一条评论
2个答案
Depending it could be the usb c port or the battery my friend had the same problem and he was told it was fried, also Nintendo has fixing services maybe call them and see. good luck
这个答案有帮助吗?
得分 0
添加一条评论
Hi Myenemy,
I found this article on Nintendo's support site:
https://en-americas-support.nintendo.com...
It sounds like you have performed some of the items the article suggests. Anyway give it a look and let me know if this works for you.
Good luck!
Will Jones
这个答案有帮助吗?
得分 0
1条评论:
I didn't know the page, but it seems I actually did all the tests.
完成的
添加一条评论
添加你的答案
myenemy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 307
