跳转到主内容
Known as the E39 , the 4th generation of the BMW 5 Series mid size sedan.
Slipping clutch maybe because of loss of viscosity?
My clutch is slipping. It is 6 spd manual. I know that it is a closed system but was wondering if it could be because I haven't ever done a transmission oil change and the viscosity is gone? Slips more when hot. 207,000 miles on car 540i M TECH Sport.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@martinflaherty no. The loss of viscosity from the transmission fluid would not affect the clutch plate. The slipping is usually because the clutch plate wears out. 200K miles on a bimmer is a pretty good lifespan. Time to replace it.
这个答案有帮助吗?
得分 3
6条评论:
Thank you, I could only hope!
完成的
@martinflaherty I know right. It’s never the easy things….best of luck to you
完成的
How much is involved in doing a clutch job on my car? Is it full engine and/or trans removal? Or, can I lift the car, split them in place and do it? I think I know the answer but am asking because I have done some jobs lately that I did way more work than needed. So it's just a shot in the dark. Thank you again.
完成的
@martinflaherty pulling the transmission is the way to go on this. I think one of the bigger PITA would be removing the exhaust. All of it requires a lot of manpower and it's all heavy and cumbersome. Better have a lift since doing it on the garage floor with a bunch of jacks is gruesome :-)
完成的
Thx. I'm not scared! lolll. I am replacing my whole main under dash wiring on my truck now. Thought it was my fault and flooded it, but found out it was mice. While there doing the heater core and more.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
MARTIN FLAHERTY 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 94
