Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
14531 个问题 查看全部
LCD has lines through it, but is not cracked.
Not sure why this would happen.
Any advice on what it could be?
I thought it was either the connecting cable or the inverter.
-Varsity
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
The LVDS cable is the video cable that carry the video signal from the logic board to the LCD panel via 2 connectors. Dark shadows can be caused by a defective backlight lamp if the shadows are starting at the screen base or by pressure points on the screen (applying excessive pressure in the screen with the fingers, etc). In the two cases the LCD panel must be replaced.
Concerning the varsityanchor lines issue, that's bad news if you get no video on the external monitor. Most of the time that leads to a defective logic board since the early MacBook Pros had problems with the Nvidia 8600 and the Ati 1600 GPUs. But you should get an image on the external if you have one (even with lines) on the internal. Are you sure the external monitor is well connected ?
这个答案有帮助吗?
按维修分数 0
添加一条评论
最有帮助的答案
Lines can be a result of either a defective LCD panel, LVDS cable, or Logic board.
you can test the MacBook Pro with an external display to rule out Logic board.. next step would be to make sure the LVDS cable is not loose, or damaged.. if all looks good.. perhaps test with a new LVDS cable. LCD is usually the last thing to go wrong. but some people are foolish enough to grab the notebook by the display.. pressure on the panel and damage the circuitry.
这个答案有帮助吗?
按维修分数 1
评论:
The MacBook Pro does work with an external display. Could it be the inverter or the display cable?
The "display cable" is called an LVDS Cable.. it is absolutely not the inverter or inverter cable -
添加一条评论
What is the LVDS cable?
i have some defect, apple says that need to replace display, i dont believe! I have some dark shadows coming from the bottom of the screen upper. Everything works well, except this inconvenience.
I will test with an external display to rule out the logic board, but what is the LVDS cables?
thankx
MacMiguel
这个答案有帮助吗?
按维修分数 0
添加一条评论
Thankx for the explanation, yours was the most clear one, the Apple guys never told a clue just saying that i must replace the Display without any detail about why.
So i can survive with the computer as it is, meanwhile i will plan what i will do in the future, buy a new LCD and replace myself, or buy a used MacBook Pro as mine and replace the complete display, or buy a new computer and sell mine for spare parts ...
thankx once more for the help
MacMiguel
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
varsityanchor 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 28
过去的30天: 106
总计 17,290
