跳转到主内容
索尼 PlayStation 5 DualSense 手柄的维修文档。 型号: CFI-ZCT1W FCC ID: AK8CFIZCT1
20 个问题 查看全部
Why does my controller still have stick drift?
A few months ago my black dual sense controller developed downward stick drift. I sprayed the joysticks with some air to try and clean it, and reset the controller with the button on the back and the drift persisted. I finally ordered some replacement sticks from amazon. The replacements I ordered were (EL6-ALPS-2.1K) and, according to the box, were manufactured by Yuyaohengzhou. First I replaced the entire left and right joysticks, not just the potentiometers, and the drift persisted. I then replaced just the potentiometers, and the drift persisted. Finally, I cleaned inside the potentiometer housing with isopropyl alcohol. The drift is still there and I’m running out of options. What else could be causing the stick drift even after all that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Maybe the replaced potentiometer could be bad from the start. My recommendation is to see if you can find a good quality potentiometer and see the drifting goes away again
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicholas Cruz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 131
