SMD resister blew out in my HP 0957 2271 AC Adapter
Want to replace but can't identify it. I don't know if anyone could help me with this but I got to try anyway.
I have a transformer the stopped working, it had a fuse that was dead that I already changed and this small smd resister which seemed to pop from the mark it left on the case. I want to try to replace the SMD, but I don't know which kind it is since the number is all burned off. so I'm posting this photo showing which one it is in hope of someone being able to tell me which SMD to put there.
Thanks in advance
P.S.
If needed I could take pictures closer or from the other side, whatever helps ^_^
7条评论
Finalpaladin, what printer are we looking at and which board is it? Is that a R48 just below the resistor? It MIGHT help to see the other side as well.
由 oldturkey03 完成的
the printer is an HP Officejet 6500. the board itself is the transformer (AC adaptor) of it's power cord. The resister is indeed R48 . I added the photo up above of the front. The fuse I switched already is the one visible on the upper left side corner if it helps.
由 Finalpaladin 完成的
Okay, looking for parts diagram of a HP 0957 2271 AC Adapter for you :-)
由 oldturkey03 完成的
Thanks, I only now noticed I could have given you the adapter number written in the back ^_^' you beat me to it.
由 Finalpaladin 完成的
Awesome, thanks a bunch, I await your answer ^_^
由 Finalpaladin 完成的
显示更多的2条评论
