跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
426 个问题 查看全部
I push the start button it dings but won't come on.
I have a duet steamer whirlpool module # wfw9600Tw01. Had error code F28 would not reset after being unplug for 10 mins tried several times door would not unlock. I took bottom off and found the pull down tab and unlocked the door but it still will not reset. Door continues to lock and will not start cycle. The power button comes on but when I push the start button it dings but won't come on. What can I do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @lisaseydler
An F28 error code indicates a communication problem between the Central Control Unit (CCU) and the Motor Control Unit (MCU).
Here's the tech sheet for the washer that may help.
Go to p.5 error code F28, to see what to check for, that may be the cause of the problem.
It also mentions how to check the doorswitch system in Step.9 of the check procedure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lisa Seydler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 16
