跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
don't have permission to change sharing permissions
hello when I get info for the ssd drive that's connected to my 2014 Mac mini sharing and permissions say that I can only read, when I unlock the padlock and enter my password I get the error The operation can't be completed because you don't have the necessary permission. I find this weird because I can copy files to and from the drive.
thanks in advance
Lethal
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like you have a second user account on this system go ito the account control panel and see if your active account has Admin status.
这个答案有帮助吗?
得分 1
21条评论:
I checked in users & groups and there is only one account and it has Admin status
完成的
@lethal99887 - Check the drives and folder permissions make sure your account (user name) is correctly entered spaces and case.
完成的
I checked the drives permissions and it says that I can only read
完成的
@lethal99887 - was this system bought used?
It sounds like the previous owner account was deleted and you just added your account.
At this point I think the smarter direction is to backup anything important and setup a bootable OS installer thumb drive so you can fully wipe the drive and install a fresh OS.
完成的
no I bought the system new , I have already wiped the drive and reinstalled and I still couldn't change permissions
完成的
显示更多的16条评论
添加一条评论
添加你的答案
Lethal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 287
