跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
702 个问题 查看全部
The dock will charge the switch, but not transfer display to the TV?
My switch will charge on the dock, but it is not transferring to the screen. I tried a friend's and it worked with no problem. I think the charging/data port might be affected by the video transfer since the charging works. Any suggestions would be greatly appreciated. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Joe,
Alisha ( @flannelist ) has been working diligently on troubleshooting guides, and I'd suggest taking a look at the No Video Out guide they've written as the place to start.
Nintendo Switch No Video Out - iFixit Troubleshooting
Other than that, it appears you're not the only person with that problem. Ethan ( @nahdoesntexist ) was having the same issue, but unfortunately did not find a solution.
SOLVED: Nintendo switch is charging, but not outputting to a TV. - Nintendo Switch - iFixit
An interesting find here was that if you take the dock connector out of the dock and plug it into the Switch it works, but once it's installed in its plastic shell it no longer works. I'm not sure if that's of any help or not.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 26
总计 99
