跳转到主内容
Samsung's third iteration of the Galaxy Watch with a newly integrated BioActive Sensor. It was released August 27th, 2021. Model SM-R860, 40 mm, non-LTE version.
19 个问题 查看全部
Brand new Galaxy Watch 4 doesn't turn on
Just arrived a brand new Galaxy Watch 4 Classic and when I tried to turn on I had the surprise that it just doesn't show any signal (vibration, sound, screen,...).
Then I tried to charge for a while it and no signal too, it got a little hot on the back after some time but just it.
What could I do to turn it on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I tried to put and pull on the charger multiple time and somehow it started showing life signs... Let's see the upcoming
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @felipebraz35835
If it is brand new and after charging it, it should work.
If it's not indicating that it is charging or that it's not turning on, contact the seller about a refund or a replacement.
The watch has a 12 month manufacturer's warranty if the seller won't co-operate so contact Samsung customer support in your location about a warranty replacement.
Do not try to open it to find out what's wrong as you will void the warranty.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Felipe Braz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 307
