screen isn't turning on after replacement
wont turn on after screen replacement
Is the original screen still in a sort of working condition so that you reinstall it to check if the problem is due to the replacement display or on the systemboard?
If not, it may come down to board level testing using the service manual to find out what's wrong.
I couldn't find a free download online, you may have better luck.
这个答案有帮助吗?
Hi @michelle51666,
See Step.51 of the ifixit Samsung Galaxy S22 Screen and Battery Assembly Replacement guide
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 62
Hi @michelle51666,
Have you checked if the display flex cable is securely connected?
由 jayeff 完成的
sm 901 and I had it all apart and put it back together everything seems in place an tight
由 michelle 完成的
i think so im no pro at all tbh i have no idea what im doing i watched alot of youtube so idk if i even know which flex cable that is
由 michelle 完成的
