跳转到主内容
The larger, fourth-generation ES (designated MCV30) debuted in July 2001 for the 2002 model year.
acceleration gives out RPMs increase
what are the potential causes of the acceleration sporadically giving out (mainly with accelerating onto a highway) and the RPMs shooting up?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Initial guess; low xmission oil, xmission pressure control solenoid(s), burned out clutch packs. Guessing is easy, diagnosing and troubleshooting requires familiarity with engines, EFI systems, electronically controlled xmissions.
完成的
添加一条评论
1个答案
It will do that if it is downshifting. If it is not, then something is slipping. Cause can be as simple as a problem with your transmission oil, or as complicated as a problem with the transmission itself.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Hardy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 69
