跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
Why is does my iPhone XR's microphone not work in speakphone?
I have an Iphone XR that has totally working microphones, except for when I'm recording voice memos or when I'm on speakerphone. The microphone works for video recording and normal phone calls. According to a search I did online, normal phone calls and voice memos use the same microphone, but for calls work but not memos, and the same can be said about speakerphone and video recording that also use the same camera but the video mic works and the speakerphone mic doesn't. I don't know if the reason for this is the recent battery replacement I did or what. Help would mean the world to me. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This sounds like an issue with one of the bottom mics.
Recording video actually does not necessarily use the same mic as speakerphone or voice memos, it depends on whether you’re recording video with the front or rear facing cameras.
Did the issue start right after you replaced the battery? If so It’s possible some damage was done to the charge port assembly, which houses the microphones also the bottom edge of the phone. If this is the case, you’ll likely need a new charge point assembly.
I would also double check that the grilles on the bottom of the phone are free of debris.
这个答案有帮助吗?
得分 1
3条评论:
I dont remember having any issues with the microphone after replacing it, but I might be wrong. I have dropped it a couple times though
完成的
Ok so I checked my ifixit history and I did the xr battery replacement guide on october 28, and I did multiple calls on that day and after with no problems so I don't think the repair caused the problem. However after looking through call history I think the microphone problems started on November third. Hope that helps
完成的
@pulpiosis Could be that it was unrelated,, I just tend to lean towards that as a possibility in cases where an issue showed up after a repair.
I would try to isolate which mic is affected and replace whichever cable assembly it's on.
完成的
添加一条评论
添加你的答案
Paul Habchy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 59
