跳转到主内容
修复你的物品
维修的权力
配件 & 工具
问题已关闭
How do I test new LCD installed in iMac g5 20"?
I took my mac to an apple store and they told me that the screen was shot. purchased a new LCD 20" screen and installed but image is still not coming. Any suggestions ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
did you check the RAM first?
Update
if your imac having display problem after minor troubleshooting assessment i think your problem is in the logic board, the gpu chip. i recommended let the tech guy to do a re-balling the gpu/bga chip not just reheating using heat gun, or if you want to do a test you can use a heat gun to your gpu, just heat 10sec to the gpu chip and try to test, if you have the display probably it was bga problem
这个答案有帮助吗?
得分 0
评论:
Thank you I will need your guidance on this one, i tried starting the comp holding down
cmd+option+p+r , i tried as well holding down the c key.
what suggestions do you have?
完成的
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 506
